henklbr
henklbr
  • Lid sinds 07 februari 2011
  • Berichten 1073
  • 18 januari 2017
  • 15:41
WARNING WARNING WARNING -> Before flashing, ACTIVATE PIN in "Secure startup" (You'll be asked for it AFTER flashing!)
This ROM is the latest ROM for Netherlands (PHN) released 19 may 17, and made it compatible for the Netherlands (PHN).
This is official Samsung ROM, so KNOX won't be triggered!
Your data will stay intact, but it's possible you get "com.android.***** has stopped" -> Then a Factory Reset is needed (in Recovery)!
What's new:
* Android 7.0
* May security patches (Samsung Android Security Updates)
* Stability Improvements
Model SM-G935F
Model name Galaxy S7 edge
Country Netherlands
Version Android 7.0
Changelist 11104523
Build date Wed, 10 May 2017 02:06:43 +0000
Security Patch Level 2017-05-01
Product code PHN
PDA G935FXXU1DQE7
CSC G935FPHN1DQD1
Download for install with Odin 3.12.3: MegaNZ
UN-RAR the archive and place the files in the designated slots in Odin 3.12.3
This package contains the HOME_CSC of the Netherlands (PHN); if you want the HOME_CSC of your own country/region, download the latest firmware of your country/region and extract the HOME_CSC which you can use with the BL AP & CP of the main package!
Bewerkt (19 mei 2017 10:54)
Greetzzz, Henk.
Android-version: 8.0.0
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 23 januari 2017
  • 12:04
This ROM is based on the the latest ROM for United Arab Emirats (XSG) released 23 jan 17, and made it compatible for the Netherlands (PHN).
Your data will stay intact, but it's possible you get "com.android.phone has stopped" -> Then a Factory Reset is needed (in Recovery)!
NOTE: If you are using this firmware with the latest Marshmallow-CSC of your region/country, it's possible 4G-calling (VoLTE) is NOT working!
This will be solved when a Nougat-CSC for your region is available!
Note2: PHN-users (Netherlands UN-branded) -> I'm on the KPN-network and have NO problems with calling!
Vodafone and/or Tele2-users could have problems with 4G-calling (VoLTE)
What's new:
* Android 7.0
* January security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Version Android 7.0
Changelist 10273029
Build date Mon, 16 Jan 2017 10:19:32 +0000
Security Patch Level 2017-01-01
Product code PHN
PDA G935FXXU1DQAS
CSC G935FPHN1BPK1
Greetzzz, Henk.
CSC: N950FOXM3CRC4
VinnyAW
VinnyAW
  • Lid sinds 28 maart 2015
  • Berichten 23
  • 1 maart 2017
  • 16:58
Hoop dat Henk ook snel met de nieuwe PHN 7.0 Nederlandse  update gaat komen
henklbr
henklbr
  • Berichten 1073
  • 1 maart 2017
  • 19:52
Jazeker: as't goed is morgenvroeg
Greetzzz, Henk.
CSC: N950FOXM3CRC4
junior_clk
junior_clk
  • Lid sinds 01 september 2015
  • 3 maart 2017
  • 20:09
helaas nog niet dus
junior_clk
junior_clk
  • 3 maart 2017
  • 21:36
Henklbr, zou jij toevallig je csc ergens online kunnen zetten?
alvast bedankt
henklbr
henklbr
  • Berichten 1073
  • 6 maart 2017
  • 09:08
This ROM is based on the the latest ROM for Nordic Countries (NEE) released 10 mar 17, and made it compatible for the Netherlands (PHN).
Note: after install of this ROM, you won't receive OTA-updates!
What's new:
* Android 7.0
* February security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Version Android 7.0
Changelist 10422490
Build date Mon, 27 Feb 2017 16:02:42 +0000
Security Patch Level 2017-02-01
Product code PHN
PDA G935FXXU1DQC1
CSC G935FPHN1DQA8
Bewerkt (10 maart 2017 15:46)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
minibrekkers
minibrekkers
  • Lid sinds 16 juni 2011
  • Berichten 2271
  • 9 maart 2017
  • 11:25
Henk.. Ik wil vandaag de NL versie zetten op mijn Zwitserse toestel (zie ander topic). Je geeft hier aan dat er op "activate pin"  geklikt moet worden maar ik heb er geen pin staan hoor. Bij mij staan patroon vereist bij inschakelen apparaat. Bedoel je dat?
Verder nog andere voorbereidingen of gewoon inpluggen en odin laten gaan…..?
*edit: het is gelukt…
Bewerkt (9 maart 2017 17:05) | Bewerkt via Tapatalk/Androidworld Reader
pieter_zegwaard
pieter_zegwaard
  • Lid sinds 24 juli 2013
  • Berichten 29
  • 13 maart 2017
  • 17:05
Bedankt
Vandaag ook op  mijn  (aut) s7 erge van belsimpel
Android 7.0 gezet.
Werkt goed .
albertoe28
albertoe28
  • Lid sinds 14 maart 2017
  • 14 maart 2017
  • 23:41
Heb dit gisteren ook geprobeerd met mn edge 7 (AUT)
Maar kreeg een fail van odin
Welke rom en home csc heb jij gebruikt?
