  • Huawei P30 Pro New Edition
henklbr
henklbr
  • Lid sinds 07 februari 2011
  • Berichten 1073
  • 12 maart 2016
  • 18:49
WARNING WARNING WARNING -> Before flashing, ACTIVATE PIN in "Secure startup" (You'll be asked for it AFTER flashing!)
This ROM is based on the the latest ROM for Netherlands (PHN) released 08 sep 16, and made it compatible for the Netherlands (PHN).
This is official Samsung ROM, so KNOX won't be triggered!
Your data will stay intact, but it's possible you get "com.android.phone has stopped" -> Then a Factory Reset is needed (in Recovery)!
What's new:
* September security patches (Samsung Android Security Updates)
* Samsung Cloud
* Gallery-app updated (à la Note 7)
* Stability Improvements
Model SM-G935F
Model name Galaxy S7 edge
Country Netherlands
Version Android 6.0.1
Changelist 9113173
Build date Mon, 29 Aug 2016 07:22:39 +0000
Security Patch Level 2016-09-01
Product code PHN
PDA G935FXXU1BPHJ
CSC G935FPHN1BPH3
Download for install with Odin 3.12.3: MegaNZ
UN-RAR the archive and place the files in the designated slots in Odin 3.12.3
This package contains the HOME_CSC of the Netherlands (PHN); if you want the HOME_CSC of your own country/region, download the latest firmware of your country/region and extract the HOME_CSC which you can use with the BL AP & CP of the main package!
Bewerkt (16 november 2016 09:55)
Greetzzz, Henk.
Android-version: 8.0.0
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 25 maart 2016
  • 08:01
What's new:
* March security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Changelist 7211170
Build date Mon, 14 Mar 2016 15:03:53 +0000
Product code PHN
PDA G935FXXU1APC8
CSC G935FPHN1APBD
Download for install with Odin 3.10.7: MegaNZ
UN-RAR the archive and place the files in the designated slots in Odin 3.10.7
Bewerkt (6 april 2016 10:22)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 6 april 2016
  • 10:21
This ROM is based on the latest ROM for Bulgaria released 04 apr 16 and made it compatible for the UN-Branded Netherlands (PHN) S7Edge.
Your data will stay intact, but it's always best to make a back-up!
What's new:
* April security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Changelist 7538748
Build date Thu, 24 Mar 2016 08:13:27 +0000
Product code PHN
PDA G935FXXU1APCH
CSC G935FPHN1APBD
Bewerkt (8 april 2016 08:53)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 8 april 2016
  • 13:43
This ROM is based on the latest ROM for Germany released 09 apr 16 and made it compatible for the UN-Branded Netherlands (PHN) S7Edge.
What's new:
* Updated Radio (CP)
Model SM-G935F
Country Netherlands
Changelist 7538748
Build date Fri, 01 Apr 2016 11:59:01 +0000
Product code PHN
PDA G935FXXU1APD1
CSC G935FPHN1APBD
Bewerkt (11 april 2016 14:09)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 18 april 2016
  • 10:02
This ROM is based on the latest ROM for United Kingdom released 18 apr 16 and made it compatible for the UN-Branded Netherlands (PHN) S7Edge.
What's new:
Model SM-G935F
Country Netherlands
Changelist 7538748
Build date Thu, 07 Apr 2016 09:48:03 +0000
Product code PHN
PDA G935FXXU1APD3
CSC G935FPHN1APC5
Bewerkt (22 april 2016 10:18)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
J.P.
J.P.
  • Lid sinds 27 mei 2013
  • Berichten 23
  • 24 april 2016
  • 16:50
Hoe kan ik de rom downloaden.
Als ik nu op mega link klik krijg ik fout melding file bestaat niet.
  • 24 april 2016
  • 17:01
 ik heb geen problemen met de download.
Misschien moet je eerst een mega account aanmaken wil de download werken.
J.P.
J.P.
  • Berichten 23
  • 24 april 2016
  • 17:16
Ok dan zal ik dat eerst doen.
J.P.
J.P.
  • Berichten 23
  • 24 april 2016
  • 17:22
J.P.
J.P.
  • Berichten 23
  • 24 april 2016
  • 21:16
Hij blijft aangeven file link niet gevonden.
Ik doe het via mobiel.
Als dit niet lukt hoop ik dat ik via een andere weg lukt want ik heb het nodig omdat mijn telefoon in een opstart loop zit.
Bewerkt (24 april 2016 21:23)
