Fcck
Fcck
  • Lid sinds 23 september 2010
  • Berichten 1732
  • 18 juni 2011
  • 00:51
Deze kernel vanStratoskis gebaseerd op deCF-Root Kernelvan Chainfireen heeft o.a. Voodoo Sound, BLN, OC/UV en vele extra tweaks.
Let Op:Deze kernel is alleen compatibel met Gingerbread ROMS!
De features van deze Semaphore Kernel zijn als volgt:
  • Voodoo Sound v10
  • Voodoo Color
  • OC/UV (1200MHz, 1300MHz)
  • BLN
  • CWM v5.0.2.7
  • Speedmod color fix
  • Patched with the latest Samsung kernel sources.
  • JVU initramfs
  • compiled with Linaro GCC 4.6.2 toolchain
  • O3 and other compiler optimizations
  • 337 MB available RAM (353 bigmem versions it breaks 720 video recording)
  • Auto brightness driver
  • Reworked cpufreq driver. cpu states 100-200-400-800-1000/1200/1300.
  • Bundled with Semaphore Script Manager to v0.62
  • su binary v3.0.3.2
  • Governor ondemand (default)
  • ondemand: sampling_down_factor tunable by momentum
  • Governor conservative (module)
  • Governor smartassV2 (module)
  • Noop I/O scheduler (default)
  • Deadline I/O Scheduler (module)
  • Simple I/O Scheduler (module)
  • Netfilter (iptables) as modules
  • TUN as module
  • CIFS as module
  • Logcat disabled (as module only)
  • cpufreq statistics as module (is loaded by default)
  • Standard network packet scheduler
  • Kernel log buffer size 4KB (from 128KB)
  • deleting boot sounds procedure creates backup on /data/local
  • Battery polling to 60 seconds
  • jhash3
  • No debug info
  • TinyRCU
  • HZ=256
  • CPU frequency on stock music player when screen off to 400 MHz
  • /system/etc/init.d directory creation if not exist
  • Custom boot animation
  • HM.Cardide's Addon scripts.
  • VM dirty chainfire's tweak as script
  • Kernel scheduler tweak as script
  • noatime chainfire's tweak by default
  • OC test scripts to 1200MHz, 1300MHz (Script Manager)
  • enabled /proc/config.gz
  • bootloop detection (clears init.d directory, if the phone does not complete 2 minutes of normal operation)
Make sure to disable this option before convert to ext4. You may enable this after the conversion!
Toelichtingen/downloads van bepaalde features:
~ Ext4 support (lagfix):
De conversie naar ext4/rfs wordt geregeld via de ext4 app. Deze simpelweg installeren en vanuit daar kun je omzetten naar EXT4/RFS.
Om te downloaden klik –> CF-Root-ext4-v1.3-Addon.apk
~ Genoemde bovenstaande features/tweaks:
Deze Features/Tweaks zijn in te stellen in de Semaphore Script Manager App die automatisch meekomt bij het flashen van de kernel.
~ Back Light Notification (BLN):
Om BLN in te schakelen download je BLN Control uit de market. Werkt standaard voor gemiste oproepen, gmail en Whatsapp, niet voor de stock sms app (geen kernel issue maar ligt aan de GB sms app). Met Go SMS werkt BLN wel.
~ CPU/OV/UV:
De CPU is standaard begrensd op 1 Ghz. Als je wilt OV/UV kun je gebruik maken van o.a. Set CPU, Pimp My CPU, Voltage Control of een andere overclock app in Google Play!
~ Wat houden al die Modules, Governor of Scheduler nou precies in(Uitleg in Engels)?
- Voor een uitleg over de Modules/Scripts van Stratosk zelf Klik Hier
- Voor een algemeenoverzicht van de verschillende Governors/Schedulers en de verschillende
betekenissen/doeleinden Klik Hier
Changelogs(engels):Downloadlinks staan onderaan!
2.7.4 (18/04/2012)
- Updated with the latest Samsung kernel sources
- JW5 initramfs (Works also on JW4.Does NOT work on previous versions)
- CPU frequency statistics built-in
- Logger built-in
- Removed Power on sound restore scripts (kernel does not remove Power on sounds, because there is enough space for ext4 conversion)
- Conservative min sampling rate 10000
- 366.4MB available RAM Verschillende Variaties]
2.7.4bmfr
- 374.8MB
- breaks 720p video recording
2.7.4bm
- 384.5MB
- breaks front camera pictures and photo capture during video recording
2.7.4sc
- 366.4MB
- stock colors
2.7.4sbf
- 374.8MB
- stock colors
-2.7.4scbm
- 384.5MB
- stock colors
- breaks front camera pictures and photo capture during video recording2.5.0 (15/01/2012)
- su permissions changed to 6755 (?)
- Added script to load configs moduleVerschillende Variaties]
2.5.0bm
- 353 MB available RAM
Breaks 720p video recording
Breaks photo capture during video recording
Breaks front camera photo capture in JVU
2.5.0sc
- Reverted Voodoo Color and Speedmod Color
2.5.0scbmLET OP:Het herstellen van Back-Ups in CWM 5 die origineel gemaakt zijn in het oudere CWM 3 is niet aan te raden. Het beste is om nieuwe Back-Ups te maken met CWM 5.
JVU_2.5.0beta (12/01/2012)
- CWM v5.0.2.7 (special thanks to Mialwe for his hints and for his mount code and of couse many thanks to CM team)
- busybox v1.19.3-cm7
- JVU initramfs
- fix front camera pictures issue
- fix capture frames during video recording (maybe dropped in final release)
- 337MB available RAM (due to the above fixes)
- updated Semaphore scripts by HM.Carbide (thanks to him, some scripts will be available as addon packages)
LET OP:Vanaf dit punt is het ZEER aan te raden om een Back-Up van je Data te maken voordat je gebruik gaat maken van een nieuwere Kernel en de nieuwe CMW versie(v5.0.2.7)
JW1_2.4.0 (30/12/2011)
- New version of Semaphore Auto Brightness driver (details here)
- Update Semaphore Script Manager application v0.71 (thanks to HM.Carbide)
- fixes bug when sampling rate is changed.
Bigmem version 2.4.0bm
- 353 MB available RAM (it breaks 720p video recording)
JW1_2.3.0 (27/12/2011)
- ondemand: is_is_busy = 0, sampling_down_momentum = 0, sampling_rate = 40000 when screen off
- Semaphore Auto brightness driver (enable through Semaphore Application - disable auto brightness from settings first, for best results set brightness to lowest value from settings)
Bigmem version 2.3.0bm
JW1_2.2.0 (23/12/2011)
- initramfs JW1
- ondemand: implemented sampling down factor
- ondemand: iowait time calculated as load (io_is_busy=1)
- ondemand: Newsampling_down_momentum tunable (explanation here)
- enabled /proc/config.gz (as module)
- updated su binary v3.0.3.2
Bigmem version 2.2.0bm
JVT_1.8.0 (To my father)
- Updated Semaphore Script Manager to v0.51 (thanks to HM.Carbide)
- dropped OC to 1100MHz (investigate again for next versions)
- Added OC test scripts to 1200MHz, 1300MHz (Script Manager)
- includes all changes of 1.8.0beta1, rc1, rc2
Bigmem version 1.8.0bm
- 352 MB available RAM (it breaks 720 video recording)
Originele threads:
- Originele Semaphore thread op XDA
- Originele CF-Root thread op XDA
- Originele HM. Carbide's Semaphore Script Manager op XDA
-Originele Website van de ontwikkelaar Stratosk
Screenshots van de bijbehorende apps in kernel:
CWM Manager (komt automatisch met de kernel mee):
Tweak Manager (komt automatisch met de kernel mee):
Ext4 addon (is te downloaden in bovenstaande toelichtingen):
Quadrant score met CPU op 1,2 Ghz (voor de gein, niet al te veelzeggend):
Downloads Kernel Versies:
Toelichting afkortingen:
SC=Stock Color
BM=Big Mem
FR=FRont camera (of FRiends)
De rest is een combinatie van bovenstaande.
Semaphore_2.7.4.tar
Semaphore_2.7.4bmfr.tar
Semaphore_2.7.4bm.tar
Semaphore_2.7.4sc.tar
Semaphore_2.7.4scbm.tar
Semaphore_2.7.4sbf.tar
Semaphore_2.5.0.tar
Semaphore_2.5.0bm.tar
Semaphore_2.5.0sc.tar
Semaphore_2.5.0scbm.tar
Semaphore_kernel_JVT_1.8.0.tar
Een beknopte Flash Guide staat in de volgende post!
Voor oudere Semaphore Kernel versies en verdere uitleg/downloads zie Stratosk Website (Semaphore - Downloads) of vraag het even in deze topic!
Bewerkt (18 mei 2015 23:00) | New Forum Capability
Fcck
Fcck
  • Berichten 1732
  • 18 juni 2011
  • 01:00
Beknopte uitleg vwb Flashen Semaphore Kernel:Credits aan topic van Lars_1808
  1. Download een van de versies van de Semaphore Kernel. Pak deze alleen uit als het niet al een .tar bestand is.
  2. Open Odin3, klik op PDA en selecteer dit .tar bestand uit stap 1.
  3. Zorg dat in Odin3 re-partition NIETaangevinkt staat.
  4. Schakel je telefoon uit en start je telefoon op in Downloadmodus, dit doe je door Volume Down-Home-Power button tegelijkertijd in te drukken.(TIP: Druk je Vol.Down en Home button eerst in en dan je Power button.)
  5. Als dit goed is gegaan zie je een gravend Androidmannetje in een gele driehoek op je scherm.
  6. Eenmaal in Downloadmodus sluit je de USB kabel aan, aan zowel je telefoon als je pc/laptop. Op dit moment geeft Odin3 links onder ID:COM: ADDED aan in het geel.
  7. Druk op start en laat Odin3 zijn werk doen.
  8. Je telefoon reboot automatisch, laat je telefoon nog aan de kabel liggen tot deze volledig is opgestart. Eenmaal opgestart kan je de telefoon loskoppelen en dan heb je de Semaphore Kernel geflashed op je SGS.
  9. Om dit te checken kun je bij "Menu-Instellingen-Over Toestel" kijken of daar Semaphore staat. Zie deze foto als voorbeeld, versies etc verschillen natuurlijk!
Bewerkt (18 mei 2015 23:01) | New Forum Capability
dherre65
dherre65
  • Lid sinds 23 april 2013
  • Berichten 1480
  • 18 juni 2011
  • 01:08
De grote voordelen ten opzichte van de Speedmod zijn:
- Voodoo Sound v9
- BLN
- OC/UV
- init.d support
- SD Card tweak
De init.d support is er voorlopig nog niet in de Speedmod kernel, en aangezien ik graag gebruik maak van Juwe's RAM script (http://forum.xda-developers.com/showthread.php?t=1111145) heb ik liever een kernel die dat wel ondersteunt.
En het werkt fijn dat je alles kan instellen via apps op je telefoon. Als je deze kernel wil proberen is het als het goed is niet nodig om de lagfix eraf te halen, aangezien Speedmod naar ext4 converteert en deze kernel die partities ook ondersteunt.
Bewerkt (18 juni 2011 01:08)
Bartito
Bartito
  • Lid sinds 11 april 2011
  • Berichten 2644
  • 18 juni 2011
  • 07:04
Mooi werk dherre65,
Was deze al op XDA tegengekomen en daar wordt hij door velen idd gebruikt.
Mooie uitleg en duidelijk
Bewerkt (18 juni 2011 07:04)
Sebastiaanlabr
Sebastiaanlabr
  • Lid sinds 30 maart 2011
  • Berichten 155
  • 18 juni 2011
  • 10:26
Lijkt me het proberen waard. Lagfix hoeft dus niet uit? En heeft de juwe tweak nog nut als je op 2.3.4 zit?
Bewerkt (18 juni 2011 10:26)
dherre65
dherre65
  • Berichten 1480
  • 18 juni 2011
  • 11:27
Bartito;179973
Mooi werk dherre65,
Dank je, hoop dat ik hier op AW ook wat mensen ermee kan verblijden.
Sebastiaanlabr;180004
Lagfix hoeft idd niet uit. En ja, het zou wel degelijk moeten uitmaken aangezien Juwe's waardes nog steeds anders zijn dan die in 2.3.4.
PS: vannacht met internet uit slechts 2% verbruikt in meer dan 9u, dat is net zoveel als ik met de Speedmod kernel haalde :-)
Bewerkt (18 juni 2011 11:27)
Desotho
Desotho
  • Lid sinds 08 januari 2011
  • Berichten 221
  • 18 juni 2011
  • 11:46
Ik ga deze kernel ook maar is uitproberen! Klinkt zeeeeer veel belovend allemaal!
Klein OT vraagje Dherre.. ik zie in je Sig dat Theme staan. Klinkt erg goed, lekker stock maar met de juist addons.. kun je mij daar een link van geven? Thanks!
Bewerkt (18 juni 2011 11:46)
dherre65
dherre65
  • Berichten 1480
  • 18 juni 2011
  • 12:19
Desotho;180023
/Offtopic:
Tiny GB Modifications by $ - xda-developers
/Ontopic: Ik zou zeggen flash hem eens, laat je bevindingen weten!
Bewerkt (18 juni 2011 12:19)
tjilitjap
tjilitjap
  • Lid sinds 07 februari 2011
  • Berichten 4703
  • 18 juni 2011
  • 12:33
Ik houd deze kernel al een tijdje in de gaten. Lijkt mij ook een prima kernel.
2 nadelen voor mij om deze bijv. in Dutch GingerPower te stoppen: 1) CWM 3.0. Veel .zips zijn hier nog niet op aangepast en veel Roms ook niet, waardoor de grijze apps ontstaan. 2) De overclock functie die erin zit. Ben er wel achter dat daar een hoop geklooi van komt. Mensen die gaan experimenteren met Overclocking en Undervolting. Niet zozeer het gevaar hiervan, dat is voor iedereen eigen risico natuurlijk, maar het fine-tunen van deze instellingen dat behoorlijk wat ervaringen en kennis vereist. Bij ook maar iets verkeerde instellingen, loopt je telefoon vast, reboot ie, of komt ie niet meer uit “deep sleep”.
Maar de vele mogelijkheden die de kernel heeft vind ik zeerrr interessant. Zeer up to date deze kernel en de makers ervan lijken me behoorlijk slimme mannen haha
Bewerkt (18 juni 2011 12:33)
dherre65
dherre65
  • Berichten 1480
  • 18 juni 2011
  • 12:35
tjilitjap;180066
Hm ik heb die gedachten wel een beetje met je gedeeld, maar ik kwam er achter dat ten eerste de meeste scripts/updates/etc. voor Gingerbread wel al compatible zijn met CWM 3, en ten tweede, over dat overclocken, ten eerste moet je een apart script aanmaken wil je überhaupt kunnen overclocken. Daarbij komt dan dat je je overclock waardes gewoon moet instellen met een app als SetCPU, en daar is het heel simpel: sleep het balkje van de maximum CPU waarde van 1000mhz naar 1200mhz, en dat was het. Veel valt er niet aan te verprutsenDe harde waardes worden door de app zelf ingesteld.
Bewerkt (18 juni 2011 12:35)
