master64nl
master64nl
  • Lid sinds 31 oktober 2011
  • Berichten 876
  • Reputatie 40
  • 10 augustus 2013
  • 15:44
Voor de Omega believers start ik deze post. Grote dank aan Indie en zijn team van het XDA forum voor deze ROM.
Wat zit er allemaal in de OMEGA ROM:
Based on firmware XXUHOF2 Android 5.0.1 (Date: 08/06/2015)
Omega Kernel v1.0 - Sources
Build from Samsung LL sources
Build with Toolchain 4.7
Selinux status set to Permissive
ExFAt sdcard support
Busybox
init.d support
Insecure
Adb Insecure
Aroma Installer
Installation is fully customizable by user and there is options to install everything or remove all Bloatware
aroma installer now has the option to remove more then 790 mb of all bloatware apps, widgets and services
Option to full wipe from aroma installer
Option to Remove all Bloatware from aroma installer - Screenshot with Omega de-bloated
Option to install or not all Omega addon apps from aroma installer
Wipe preload automatic before roms installation
Wipe cache automatic before roms installation
Wipe dalvik cache automatic during installation
Wipe System automatic before roms installation
Omegas Emblem Bootanimation by our artist anbech
Omegas Emblem Shutdown animation by our artist anbech
OmegaDroid Wallpapers by our artist Jorq1H
Omegas multi csc
init.d support for stock kernel
busybox
Applications developed by Omegas Team (bartito & indie):
Omega Files by indie
OmegaDroid - The official application of www.omegadroid.co by indie
OmegaDroid Wallpapers application - Screenshot by indie
Task manager shortcut app by indie
Accounts Sync Profiler - xda thread for support & suggestions - Play Store link - by bartito
Backup manager for apps & data - xda thread for support & suggestions - Play Store link - by bartito
CPU Adjuster - xda thread for support & suggestions - Play Store link - by bartito
Notification Manager - xda thread for support & suggestions - Play Store link - by bartito
Recycle Bin - xda thread for support & suggestions - Play Store link - by bartito
Wireless Scheduler - xda thread for support & suggestions - Play Store link - by bartito
more to come ….
Mods:
Call Recorder
Phone with no increasing ringtone
3MinitBattery Mod - Full credits to gharrington
5-way reboot menu
TW Launcher with scrolling wallpaper (can be disabled from Omega Files)
Email with Exchange Security Disabled
No sms to mms conversion
Unlimited contacts to sms - mms
sms save and restore option
Increased sms hour limit to 1000
extSdCard write permissions fixed
Screen Mirror Fix for Stock Kernel
S Health Fix
Exit button to stock browser
Join more unlimited contacts in the contacts
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Enable sub Symbols on Stock Samsung keyboard
Camera shutter sound on-off
Removed S Finder Big Buttons from Notification bar - Can be Restored from Omega Files
Accuweather Widget Note 4 with transparency option - credits to Albe95
build.prop tweaks
Addon applications:
Android Camera
Flash player Support
Dolphin Browser with Flashplayer support
Dolphin Browser Jet Pack
Es File Explorer
Hide It Pro
ZArchiver
Hi-Q MP3 Recorder
Phone INFO Samsung
Easy call recorder
Removed:
Knox
Boot sound (Can be added from Omega Files)
Charger Connection Sound
Rom is Deodexed + Rooted + Zipaligned
Lees dit eerst voordat je gaat flashen!
knox:
The new Omega is based on Samsung Android firmware and it needs a custom recovery for the installation.
This mean the knox will be triggered and your warranty will be void, more info:
All you wanted to know about KNOX Void Warranty 0×1
Omega Files Repo:
Omega Files repo is ready and included in Omega Files Free and Pro
Wipe:
This Omega Rom version is a No Full wipe rom but Full Wipe is recommended if you have issues.
Backup:
Make sure to make and keep in a safe place an efs backup - nadroid backup - titanium backup - etc, in case you ever need to restore!
Installation:
1. Backup your device (nadroid backup, titanium backup, efs backup … etc) and save the backup to a safe place.
2. Flash a custom recovery compatible with Lollipop (Latest TWRP is the recommended one) with odin
3. Boot to Recovery (if you are using Philz recovery flash from internal sdcard only) and flash Omega, first boot will take about 25 to 30 minutes
FULL INSTALLATION GUIDE by our Omega Team Member CarlM34 AVAILABLE AT THIS POST
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
Data apps:
Flashing Rom with Full wipe or with No Full Wipe some applications installed at data/app folder (like Omega Files, OmegaDroid, Chrome, STranslator etc)
All this data apps can not be removed because android 5.0 (lollipop) treats them like system apps and after a reboot they are reinstalled even if you remove them.
This data/apps are necessary to keep system partition with enough free space.
To remove this apps here are some options:
1. Do not install apps you do not need during flash (deselect them from aroma)
2. Use this flashable aroma zip file to remove them after flashing Omega rom (very easy to do)
3. Delete them yourself from data/app folder (not so easy)
Tips:
*SuperSu: If needed open SuperSu and update SU binary, then choose normal and reboot device.
*For Accuwheather widget transparent go to Accuwheather widget Settings and select the Widget transparency you like
*To change Battery icons use 3minit batteries app, more than a thousand battery icons included.
*3Minit Battery mod can be removed from Omega Files
*Change Battery icons to Stock from 3Minit Battery app if you want to keep Sfinder buttons hidden at Notification Panel
** If you flash Stock Kernel wifi will not work
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation - Screenshot with Omega fully debloated
http://forum.xda-developers.com/showpost.php?p=61919757&postcount=26549
Bewerkt (8 september 2015 09:29)
Groetjes
primo
primo
  • Lid sinds 28 juli 2012
  • Berichten 13
  • 11 augustus 2013
  • 10:41
vraagje ik heb dit geprobeerd te instaleren maar hij zegt nu allen dat me s4 niet meer geroot is
enig idee wat ik hier fout doet
ik doe dit met odin 3.6
ga naar pda klik die md5 van 1.6 gb aan en dan doet hij wel wat hij moet doen
maar als hij dan gereboot is dan staat er niets van omega
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 11 augustus 2013
  • 12:45
Primo, heb je wel gelezen op XDA forum wat je moet doen voordat je deze flasht?
Het is een zip bestand dat je op je extSdCard zet (in een map Omega ROM evt.)
- Je reboot in recovery mode.
- Kies: Install Zip
- Kies: Choose zip from External sdcard
- Kies: De map waar je het zipbestand heb staan
- Installeer zipbestand
- Kies: Installeer zipbestand
Dus zonder wipe maar gewoon instaleren.
Groetjes
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 2 september 2013
  • 08:56
Omega v10 is er!
Ik heb problemen er mee:
Hij zegt steeds dat de ext-sd er uit mag maar ik kan hem niet meer aanmelden en mounten lukt ook niet. Dus ik kan geen backup terug zetten van de ext-sd. Ik heb de backup op de interne-sd gezet in clockworkmod/backup maar krijg dan de melding dat hij deze map niet kan openen.
Heeft iemand een idee hoe ik mijn oude backup terug krijg? Ik heb een backup gemaakt voordat ik ging flashen.
Uiteindelijk wel gelukt met de app ROMManger om een backup terug te zetten.
Bewerkt (2 september 2013 12:51)
Groetjes
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 18 september 2013
  • 20:18
Omega v11 is er en ik ben ondertussen achter hoe je bepaalde problemen kan omzeilen.
Het niet herkennen van je externe-sd met CWM om bijv. advanced retore (nandroid backup data terug zetten) te doen komt door de versie 6.0.3.2
Je moet i9505-cwm-recovery-6.0.3.2(0611).tar met odin er op zetten om weer vanaf je externe-sd te kunnen flashen of wat dan ook.
Je kan mazzel hebben door een met een no wipe te flashen en geen WIFI of modem issues te hebben. Dit kun je oplossen door de ZHUDMH6 LTE modem te flashen.
Gebruiksaanwijzing heb ik even in het Engels hier onder gezet.
Wipe:
Omega v11 is a No Full wipe rom, but Full wipe is strongly recommended if you have issues!
Backup:
Installation Instructions:
1. Backup
2. Copy rom to your device and flash it from recovery, recommended Recovery: TWRP Recovery - Boot to Recovery and flash Omega Rom.
There is no need to flash Stock Rom first, Flash Omega with or without wipe from Recovery and reboot device to Android
3. If wifi is not working do this to fix it:
Download ZHUDMH6 LTE modem (Modem can also be downloaded from Omega Files Free & Pro).
Power off your device completely, then power it up again to download mode (do not reboot at once to download mode)
Flash with odin ZHUDMH6 LTE modem, if wifi is not fixed then flash again the new LTE modem with odin and check again.
Notice this will not change your GSM Modem, if you want to change it then you can do it form Omega Files
csc:
Remove bloatware:
You can know remove all bloatware during Omegas installation
Ik heb gewoon een data factory reset en full wipe installatie gedaan. Als je de juiste CWM er op hebt staan kun je gewoon een advanced retore (nandroid backup data terug zetten) doen en alles is weer zo als het was.
Bewerkt (18 september 2013 20:30)
Groetjes
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 28 september 2013
  • 09:22
Omega v.12 is uit, lees dit eerst voordat je gaat flashen!
Wipe:
Omega v12 is a No Full wipe rom, but Full wipe is strongly recommended if you have issues!
Backup:
1. Backup
Download ZHUDMI1 LTE modem (Modem can also be downloaded from Omega Files Free & Pro).
Flash with odin ZHUDMI1 LTE modem, if wifi is not fixed then flash again the new LTE modem with odin and check again.
Notice this will not change your GSM Modem, if you want to change it then you can do it from Omega Files
Kernel:
Stock kernel can not be used to the new firmwares.
The custom kernel Omega uses can be changed with the one you like easily.
csc:
Remove bloatware:
Groetjes
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 30 september 2013
  • 18:42
Staat nu ook in de openingspost onderaan voor de Omega believers.
Groetjes
roelh
roelh
  • Lid sinds 24 december 2010
  • Berichten 669
  • 30 september 2013
  • 21:49
Ik draai sinds 2 dagen deze rom. Werkt prima tot nu toe!
master64nl
master64nl
  • Berichten 876
  • Reputatie 40
  • 1 oktober 2013
  • 06:17
Hi Roel, leuk te horen dat je tevreden bent met deze rom. Heb je de vorige versies ook al gehad of is v.12 de eerste?
Groetjes
Stalkerken
Stalkerken
  • Lid sinds 06 november 2012
  • Berichten 56
  • 1 oktober 2013
  • 12:59
Kan je de app die het weer enzo weergeeft ook afzonderlijk downloaden ?
Join Hattrick!!!Het meest verslavende online voetbalmanagerspel!
